2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
315.101371
Background
The Craftsman Hammer Drill, model number 315.101371, is a tool designed for drilling and hammering applications. It is produced by Diehl Manufacturing Co. for Sears under the Craftsman brand. The tool is designed to use an alternating current power source, specifically a 120V, 60Hz, 6A supply.
The hammer drill has several functional features. One of the primary features is the variable speed switch, which allows the user to adjust the speed of the drill according to the pressure applied. The drill also has a keyless chuck, which enables the user to tighten or release the drill bit in the chuck jaws by hand. The hammer drill comes with a direction of rotation selector for changing the direction of bit rotation. Another notable feature is the auxiliary handle that provides ease of operation and helps prevent loss of control. The tool also includes levels on the top and end of the motor housing to help keep the drill bit level during use. Additionally, the live tool indicator, located on the handle of the drill, shows when the tool is connected to a power supply. The spindle lock keeps the chuck from turning while installing and removing bits. The hammer drill has a hammer speed of 0-16,000 blows per minute (BPM).
Technical Specifications
- Model Number: 315.101371
- Product Type: Hammer Drill
- Chuck: 1/2 in. Keyless
- No Load Speed: 0-1,000 rpm
- Blows Per Minute (BPM): 0-16,000
- Input: 120 V, 60 Hz, AC only, 6 Amps
- Net Weight: 5.02 lbs
