5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
315.21211
Background
The Craftsman 315.212110 is a miter saw primarily designed for making precise, angled cuts in various materials such as wood and plastic. Manufactured by Diehl Mfg Co for Sears, the saw is identified by its 10-inch blade. This saw is a type of compound miter saw, meaning it has the capability to pivot left and right for angled cuts and tilt in a single direction for beveled cuts.
The Craftsman 315.212110 is powered by a 15 amp motor that operates at a no-load speed of 4600 rpm. It has a miter angle range of 0-57 degrees to the left and right, with pre-set stops at certain angles. Additionally, it has a bevel range of 0-45 degrees. The saw is equipped with a dual horizontal steel rail system, enabling the head to slide for cuts on wider boards, extending the cutting capacity to 12 inches. The product comes with various accessories such as a work clamp and dust bag.
Technical Specifications
- Model number: 315.212110
- Product type: 10 inch sliding compound miter saw
- Motor power: 15 amps
- No load speed: 4600 rpm
- Arbor size: 5/8 inch
- Blade diameter: 10 inch
- Bevel range: 0-45 degrees
- Miter angle range: 0-57 degrees to both left/right
- Cutting capacities:
- Cross cut at 90°: 12 inches
- Cross cut at 45° bevel: 8 inches
- Miter at 45°: 8 inches
- Nested crown molding vertically: 5-1/2 inches
- Table size: 24 x 17 inches
- Rail slide length: 12 inches
- Weight: 67 lbs
- Included accessories: Work clamp, dust bag, two table extensions, stop block, small wing screw, two clamp brackets, and two clamp bracket screws.
Warranty
The Craftsman 315.212110 comes with a 2 year limited warranty provided by Sears. This warranty covers any defects in materials or workmanship for a period of 2 years from the date of purchase. However, it's important to note that the warranty does not extend to normal wear parts such as brushes, blades, guards, and more. In order to claim the warranty, proof of purchase is required, which implies that the product must have been purchased from an authorized seller and within the warranty period.
