3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
315.23743
Background
The Craftsman 7.5 inch Radial Arm Miter Saw model number 315.23743 is an electrically powered tool designed for various types of wood cutting. It is equipped with a 7.5 inch diameter blade that rotates at a speed of 5500 RPM, enabling it to cut wood up to a thickness of 2-3/8 inches. The miter saw includes a radial arm, which facilitates the sliding motion of the saw head for enhanced cutting efficiency. Additionally, the saw features a mechanical blade brake that halts the blade's movement swiftly after a cut is made.
The Craftsman 7.5 inch Radial Arm Miter Saw model number 315.23743 has a range of specifications that enable precise and versatile cutting. It has a motor with a 12-amp capacity and a speed of 5500 RPM. The saw's blade has a diameter of 7.5 inches, with an arbor size of 5/8 inch. The miter capacity for both left and right directions is 47.5 degrees, while the bevel capacity ranges between 45 and 90 degrees. The miter saw is designed with adjustable miter and bevel angles, along with quadrant scales for precision. The 315.23743 model is intended for use in home DIY projects, and with the right care, it can deliver precise cuts for various woodworking tasks.
Technical Specifications
- Model Number: 315.23743
- Product: Craftsman Miter Saw 315.23743
- Product Type: Miter Saw
- Motor: 12 amp, 5500 RPM, electric
- Blade Diameter: 7.5 inches
- Arbor Size: 5/8 inch
- Maximum Miter Capacity (Left/Right): 47.5 degrees
- Maximum Bevel Capacity (Left/Right): 45-90 degrees
- Cutting Capacities at 0 Degree Miter: 9-7/8 inches wide
- Cutting Capacities at 45 Degree Miter: 7-3/8 inches wide
- Cutting Capacities at 0 Degree Bevel: 2-3/8 inches thick
- Cutting Capacities at 45 Degree Bevel: 1-5/8 inches thick
- Table Size: 18 x 12 inches
- Turntable Diameter: Approx 12 inches
- Weight: Approx 50 lbs
