4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
315.24315
Background
The Craftsman Miter Saw 315.243150 is a cutting tool manufactured by Diehl Mfg Co for Sears under the Craftsman brand. This particular model is a compound miter saw, characterized by a 10-inch blade diameter and a corded electric power source. The saw features a motor of 15 amps allowing it to reach a no-load speed of 5,000 RPM. The table size is 20 x 12 inches, with an overall weight of 35 lbs.
The saw is designed to carry out a range of angled cuts with its blade tilt that can be adjusted left and right up to 47 degrees and miter angle range of up to 50 degrees left and right. Furthermore, it is capable of cutting a maximum thickness of 3-1/2 inches vertically and 2x lumber at 45 degrees. The saw includes features such as dual bevel scales for precise adjustments, an electric blade braking system, tall sliding fences to support molding, a laser marker for cutting accuracy, a spindle lock for blade changes, and a dust collection bag.
Technical Specifications
- Model Number: 315.243150
- Product Type: Miter Saw
- Blade Diameter: 10 inches (254 mm)
- Arbor Size: 5/8 inches
- Blade Tilt: Left and right up to 47 degrees
- Miter Angle Range: Left and right up to 50 degrees
- Max Cutting Thickness: 3-1/2 inches vertical, 2x lumber at 45 degrees
- No Load Speed: 5,000 RPM
- Power Source: Corded electric
- Motor: 15 amp
- Table Size: 20 x 12 inches
- Weight: 35 lbs
Warranty
The Craftsman Miter Saw 315.243150 comes with a limited warranty that lasts for 1 year. This warranty covers any defects that may arise from materials or workmanship. However, it's important to note that the warranty does not extend to normal wear and tear, misuse or abuse of the product. To make a warranty claim, it's usually necessary to contact the manufacturer, Craftsman, directly, providing proof of purchase and details of the defect. It might also be necessary to send the product for inspection or repair. The specific processes may vary, so it's recommended to consult the product's manual or Craftsman's official website for detailed instructions.
