2 Diagrams
No Answers 0 Score |
How to install a new carburetor |
Documents
Models
580.752
Background
The Craftsman 580.752000 is a pressure washer designed for domestic use. Developed by GOLDSTAR for Sears, under the Craftsman brand, this washer is equipped with a 3.75 horsepower Briggs & Stratton gas engine, capable of generating a water pressure of up to 2,000 PSI with a flow rate of 2.0 gallons per minute.
The specifications of the Craftsman 580.752000 pressure washer include a 1-quart fuel tank capacity, an Axial cam pump, a 25 ft high-pressure hose, and a 1/2 gallon soap tank. It has a weight of 48 lbs. The washer features a Briggs & Stratton engine, a turbo nozzle that rotates the spray in a circle for increased scrubbing action, an onboard detergent tank for the application of soaps and cleaners, and an automatic cool-down system that helps prevent the pump from overheating.
Technical Specifications
- Engine: 3.75 HP Briggs & Stratton 10D902
- Fuel tank capacity: 1 quart
- Pump: Axial cam pump
- Pressure: Up to 2,000 PSI
- Flow rate: 2.0 GPM
- High pressure hose length: 25 ft
- Soap tank capacity: 1/2 gallon
- Weight: 48 lbs
Warranty
The Craftsman 580.752000 Pressure Washer comes with a 1-year limited warranty. This warranty primarily covers any defects in materials and workmanship. It is important to note, however, that any damage resulting from improper storage or lack of maintenance is not covered under this warranty. To claim the warranty, it would likely require contacting Sears or the place of purchase, providing proof of purchase, and detailing the nature of the issue.
