8 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
315.218061
Background
The Craftsman 315.218061 is a table saw produced by Diehl Mfg Co for Sears under the Craftsman brand. This particular model is a 10-inch table saw intended for a variety of woodworking operations such as ripping, crosscutting, mitering, and beveling. It is suitable for working with wood and wood composite materials.
The Craftsman 315.218061 table saw offers a range of features to enhance its functionality and user convenience. It includes a large cast iron table surface, a sliding miter table, quick release clamps, a bevel adjustment handwheel, a front-mounted bevel and miter scales, a blade guard assembly, a leg stand with wheels, storage hooks, table extension, and rear outfeed support. These features collectively contribute to the saw's accuracy, ease of use, and adaptability to different woodworking tasks. For instance, the large cast iron table surface and table extension provide ample support for smooth feeding of workpieces, while the sliding miter table enables wider crosscuts. The quick release clamps allow for fast locking and unlocking of the miter gauge and rip fence, and the bevel adjustment handwheel and bevel locking lever facilitate convenient control of blade tilt angle. Additionally, the blade guard assembly helps contain dust and prevent kickback.
Technical Specifications
- Model Number: 315.218061
- Product Type: Table Saw
- Blade Diameter: 10 inch
- Arbor Size: 5/8 inch
- Blade Bevel Adjustment: 0 to 45 degree
- No Load Speed: 5000 RPM
- Blade Type: Left-tilting blade
- Depth of Cut at 90 Degrees: Maximum 3-1/2 inch
- Depth of Cut at 45 Degrees: Maximum 2-1/2 inch
- Table Size: 25-1/2 x 17 inches
- Motor: 15 amp
- Operation Voltage & Frequency: 120V, 60Hz
- Weight: 61.5 lbs (without stand), 82.5 lbs (with stand)
Warranty
The Craftsman 315.218061 table saw comes with a 1-year full warranty, covering any defects in materials and workmanship. However, for commercial or rental use, the warranty period is shortened to 90 days. It's important to note that this warranty is applicable only when the product is used within the United States. To claim the warranty, adhere to the guidelines and instructions provided in the operator's manual. It is usually required to provide proof of purchase, and it may also involve contacting the manufacturer or the authorized dealer from whom the product was purchased.
