8 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.29908
Background
The Craftsman Tiller 917.299080, manufactured by Roper Corp for Sears, is a piece of gardening equipment used for turning soil. This rear-tine rototiller is designed for tasks such as preparing garden beds and cultivating small farming plots. It features a 208cc 4-cycle LCT engine, which runs on unleaded gasoline. The machine also boasts both forward and reverse tine rotations, which cater to different tilling and cultivating needs.
The tiller has a tilling width of 12 inches, with options to adjust the tilling depth up to 6 inches. The device is equipped with 8-inch diameter plastic wheels and has a sealed gear transmission. Other features include a drag stake for controlling tilling speed, adjustable handles with three positions, and side shields to safeguard plants. The tiller weighs roughly 100 lbs and measures 24 x 25 x 40 inches in length, width, and height respectively. Regular maintenance such as changing engine oil, cleaning or replacing the air filter, checking tire pressure, lubricating gears and wheels, and inspecting tines and belts is recommended for the longevity of the product.
Technical Specifications
- Engine: 208cc LCT 4-cycle
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 3 qt
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Tines: 12 in tilling width, counter-rotating and forward-rotating
- Wheels: 8 in diameter plastic
- Transmission: Sealed gear, forward and reverse
- Weight: Approximately 100 lbs
- Dimensions: 24 x 25 x 40 in (Length x Width x Height)
- Tilling Depth: Up to 6 in
Warranty
The Craftsman Tiller 917.299080 comes with a 2-year limited warranty. This warranty typically covers any defects in the materials or workmanship of the product. If within these two years, the tiller fails due to a manufacturing defect, the company will repair or replace it. To claim the warranty, you would generally need to contact the manufacturer, Sears, directly. You would likely need to provide proof of purchase, such as a receipt, and describe the issue you're experiencing. It's always recommended to refer to the specific warranty documentation provided with the product for full details on what's covered and the claim process.
