2 Diagrams
No Answers 0 Score |
The washer between the string holder and it say number 25 I need that |
Documents
Models
358.795543
Background
The Craftsman Trimmer 358.795543 is a gas-powered trimmer that has been designed for light trimming and edging tasks around a yard. It features a 2-cycle gas engine and employs a 17 inch cutting path using a nylon trimmer line. This trimmer advances the line automatically, removing the need for user interaction to extend the line. Additionally, it has a handle that can assist with control and can pivot for edging tasks.
This tool's specifications include a 25cc/1.5 cu.in. 2-cycle engine, a cutting path of 17 inches, and a line diameter of 0.080 inches. The trimmer uses a 40:1 gas/oil mix for fuel and has a weight of approximately 10 lbs. The Craftsman Trimmer 358.795543 consists of several parts including an engine assembly with a fuel tank, an assist handle, a debris shield, a trimmer head assembly, a spark plug and boot, a starter rope and handle, a primer bulb, and an on/off switch.
Technical Specifications
- Model Number: 358.795543
- Product Type: Trimmer
- Engine: 25cc/1.5 cu.in. 2-cycle engine
- Cutting Path: 17 inches
- Line Diameter: 0.080 inches
- Fuel Type: 40:1 gas/oil mix (3.2 oz oil per 1 gallon gas)
- Displacement: 25cc
- Power: 1.5 cu. in.
- Weight: approx. 10 lbs
Warranty
The Craftsman Trimmer 358.795543 comes with a comprehensive 1-year warranty. This warranty covers any defects in materials or workmanship on non-commercial usage. Among the components covered are the carburetor and the ignition system, however, expendable parts such as the trimmer line, spark plug, and air filter are not included in the warranty coverage. In order to claim the warranty, the repair or replacement of defective parts must be done by a Sears service center.
