2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79563
Background
The Craftsman Trimmer 358.795630 is a gas-powered hedge trimmer with a 21cc, 2-cycle, air-cooled engine. This trimmer utilizes a fuel/oil mix ratio of 40:1, with a solid state ignition system and a maximum engine revolution per minute (RPM) of 9,000. The cutting blade is 22 inches long and operates using a dual reciprocating mechanism. Additional features include a spark plug with a gap of 0.024-0.028 inches and a rotating rear handle that can pivot up to 180 degrees, which enables trimming at various angles.
The 358.795630 model is designed for homeowner use, with a lightweight construction of 9.7 lbs when dry. It has front and rear rotating handles to provide control during operation. An adjustable debris shield is present to protect the user from flying debris. This trimmer requires a 40:1 fuel mixture of unleaded gasoline and 2-cycle air-cooled engine oil to function. This model also comes with an adjustable shoulder strap for ease of use.
Technical Specifications
- Model Number: 358.795630
- Product Type: Trimmer
- Engine: 21cc, 2-cycle, air cooled
- Fuel/Oil Mix Ratio: 40:1 (3.2 oz oil per gallon gas)
- Ignition: Solid state, fixed timing, 0.010-0.014" spark plug gap
- Spark Plug: Champion RCJ-8Y, 0.024-0.028" gap
- Maximum Engine RPM: 9,000
- Cutting Blade: 22" dual reciprocating
- Weight: 9.7 lbs dry
- Handles: Front and rear rotating
- Debris Shield: Adjustable
- Safety Features: Throttle trigger lockout, hand guard
- Accessories: Adjustable shoulder strap
Warranty
The Craftsman Trimmer 358.795630 comes with a full 1-year warranty against defects in materials and workmanship, provided the product is used in a non-commercial setting. The warranty covers the costs associated with the repair or replacement of defective parts, under the condition that the trimmer has been operated and maintained according to the guidelines provided in the owner's manual. However, it is important to note that normal wear items such as the spark plug, air filter, and cutting blade are not included in the coverage of this warranty. To claim the warranty, the trimmer needs to be returned to the nearest Sears store.
