2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79579
Background
The Craftsman Trimmer 358.795790 is a gasoline-powered hedge trimmer. It is equipped with a 19-inch double-sided blade and operates on a 2-stroke 25cc engine, providing the ability to trim branches up to 7/16 inch in diameter. The fuel for the trimmer is a mix of unleaded gasoline and 2-cycle air-cooled engine oil at a ratio of 40:1. The trimmer weighs 10 lbs, making it portable and convenient for the user.
The trimmer has several features such as an ON/OFF switch, a choke lever for cold starts, and a throttle trigger for control. It also features a primer bulb that aids in easy starting of the machine. An idle speed adjustment screw is provided to regulate the engine's idle speed and a handguard is also present to provide some protection for the operator.
Technical Specifications
- Engine Type: 25cc 2-cycle engine
- Fuel Mix Ratio: 40:1 gasoline to oil
- Fuel Type: Unleaded gasoline mixed with 2-cycle air-cooled engine oil
- Blade Length: 19 inches
- Cutting Capacity: Branches up to 7/16 inch diameter
- Weight: 10 lbs
- Spark Plug Type: Champion RCJ-6Y
Warranty
The Craftsman Trimmer model 358.795790 comes with a one-year warranty that covers defects in materials and workmanship. This warranty ensures repair or replacement of faulty parts provided the product is used and maintained according to the instructions given in the manual. However, it's important to note that the warranty does not cover normal wear parts such as the spark plug, air filter, and blade. Furthermore, usage of the product for commercial and rental purposes is covered but for shorter periods. To claim the warranty, ensure you have followed the product's usage and maintenance instructions as specified in the manual.
