5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.28282
Background
The Craftsman Walk Behind Mower 247.282820 is a lawn dethatcher designed to break up and remove layers of dead grass and debris, commonly known as thatch, from lawns. This process supports improved water and nutrient absorption by the soil. The dethatcher is equipped with a 163 cc overhead valve engine that provides torque of 6.75 ft-lb. This engine uses regular unleaded gasoline and 10W-30 oil.
The machine's operational features include a cutting width of 21 inches, facilitated by 21 steel blades that can adjust to cut up to 1/8 inch into the soil. The machine is designed to cover up to 6,000 sq ft per hour. The dethatcher is fitted with 8 x 2.125 inch front wheels to aid maneuverability. The dethatcher frame is made of steel, with a belt-driven steel blade reel and steel debris shield. The height adjustment lever allows for variable cutting depth. When maintenance is required, the steel blades are replaceable.
Technical Specifications
- Engine Type: 6.75 ft-lb overhead valve engine
- Engine Displacement: 163 cc
- Fuel Type: Unleaded gasoline
- Oil Type: 10W-30
- Cutting Width: 21 inches
- Number of Blades: 21 steel blades
- Cutting Depth: Adjustable up to 1/8 inch
- Wheel Size: 8 x 2.125 inch front wheels
- Weight: 68 lbs
- Dimensions: 21 x 23 x 41 inches
Warranty
The Craftsman 21 Steel Blade Dethatcher (Model 247.282820) comes with a 2-year limited warranty provided by Craftsman. This warranty covers defects in materials or workmanship for the mentioned time period. In order to claim the warranty, one must typically contact the Craftsman customer service or the retailer where the product was purchased. It's essential to keep the receipt or any other proof of purchase, as it might be required during the warranty claim process. However, the specifics of how to claim the warranty can vary, so it's recommended to check the user manual or Craftsman's official website for exact procedures and contact details.
