1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.37037
Background
The Craftsman Walk Behind Mower 247.37037 is a gas-powered lawn mower designed for residential use. It is equipped with a 21-inch steel mowing deck and it is driven by a Briggs & Stratton engine. The engine has a displacement of 163 cc and generates 5.0 gross HP. The mower has a fuel capacity of 0.9 gallons and offers a cutting width of 21 inches. It also allows for a cutting height between 1 to 3 inches, adjustable in 7 positions. The mower features 7-inch front wheels and 11-inch rear wheels, and it weighs 95 lbs.
The mower is capable of side discharge, mulching, or rear bagging. It is equipped with a single lever for adjusting the mowing height. The mower is designed to be started easily, with a quick pull of the starter rope. For maintenance, it requires regular inspection of control linkages, air filter, and mower blade, along with oil changes and cleaning of the mower deck underside. The mower's performance can be optimized by avoiding mowing wet grass or grass higher than 4 inches.
Technical Specifications
- Model Number: 247.37037
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 128M02-0952-F1/128M02-1612-F1
- Displacement: 163 cc
- Power: 5.0 gross HP
- Fuel Capacity: 0.9 gallons
- Cutting Width: 21 inches
- Cutting Height: 1-3 inches (7 positions)
- Deck Material: Steel
- Wheels: 7 inch front, 11 inch rear
- Weight: 95 lbs
Warranty
The Craftsman Walk Behind Mower 247.37037 comes with a full warranty that is valid for 2 years from the date of purchase. This warranty covers defects in materials and workmanship, offering repairs or replacement if a repair isn't possible. However, please note that the warranty does not cover normal wear parts such as blades, belts, filters, etc. The engine warranty is separately covered by Briggs & Stratton. To claim the warranty, refer to the operator's manual or contact the manufacturer directly.
