7 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.37108
Background
The Craftsman Walk Behind Mower 247.37108 is a lawn mower with a self-propelling function. It is produced by the Sears Brands. This model features a Briggs & Stratton engine with a 163cc capacity and 6.75 ft-lbs gross torque. The mower's cutting deck is 21 inches wide and offers mulching and side discharge options. The height of the deck can be adjusted to seven different positions, ranging from 1-1/2 to 4 inches. The mower's self-propulsion is controlled by a variable speed control mechanism located on the upper handle.
The engine model that powers the mower is the Briggs & Stratton 625 series, specifically model number 12P902-0783-B1. It operates using regular unleaded gasoline and has an oil capacity of 18 oz. The spark plug used in the engine is a Champion RC12YC. The rear wheel drive system is engaged by the variable speed control on the handle, which allows the mower to propel itself at the operator's pace.
Technical Specifications
- Model Number: 247.37108
- Product Type: Walk Behind Mower
- Cutting Deck: 21 inch with mulching and side discharge options
- Engine: Briggs & Stratton, 163cc, 6.75 ft-lbs gross torque
- Drive System: Self-propelling rear wheel drive with variable speed control
- Height Adjustment: 7 position adjustment from 1-1/2 to 4 inches
Warranty
The Craftsman Walk Behind Mower 247.37108 comes with a 2-year full warranty, which covers any defects in material and workmanship. If a repair is not possible, Sears will provide a replacement. However, this warranty period is reduced to 1 year if the mower is used for commercial purposes. It's important to note that expendable parts like blades, belts, blade adapters, and the like are not covered under this warranty. In addition to this, the engine manufacturer offers a separate warranty for emission control defects. To claim the warranty, contact Sears or the engine manufacturer, as appropriate, and provide the necessary information about the defect.
