1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.38821
Background
The Craftsman 247.388210 is a walk-behind lawn mower that features a 21-inch cutting width. The mower is powered by a 163 cc Briggs & Stratton engine, which operates on unleaded gasoline and SAE 30 oil. Cutting height can be adjusted between 1 and 3 inches, providing flexibility for different lawn conditions. The unit uses a rear bag grass collection system with a capacity of 2.4 bushels, facilitating the clean-up of cut grass.
The mower is typically used for residential lawn care. The engine propels a rotary blade housed within a steel mower deck to cut grass. The blade is engaged by holding down a control handle and the engine is started by pulling a cord. The mower discharges clippings towards the rear into the attached collection bag. The machine weighs around 60 lbs and the design of the engine is attributed to Briggs & Stratton.
Technical Specifications
- Engine Type: Briggs & Stratton 163 cc overhead valve engine
- Power: 5.5 ft-lbs gross torque
- Fuel Type: Unleaded gasoline
- Oil Type: SAE 30 oil
- Oil Capacity: 18 oz
- Cutting Width: 21 inches
- Cutting Height Range: 1-3 inches adjustable
- Grass Collection: 2.4 bushel rear grass bag
- Weight: 60 lbs
Warranty
The Craftsman 247.388210 walk-behind lawn mower comes with a 2-year limited warranty. This warranty covers protection against defects in materials and workmanship of the product. To claim the warranty, ensure that you have properly maintained the product as per manufacturer's instructions, including routine maintenance like oil changes, air filter cleaning, and blade sharpening for optimal performance. If defects or issues arise within the warranty period, contact the manufacturer or your retailer with proof of purchase for support and potential repairs or replacements.
