2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.88921
Background
The Craftsman Walk Behind Mower 247.889210 is a gas-powered lawn mowing machine. Manufactured by MTD for Sears under the Craftsman brand, this machine is designed to be used manually by walking behind it and guiding its path. The mower's primary function is to cut grass in a variety of outdoor spaces, such as residential lawns or commercial landscapes.
The mower is equipped with a 179cc Kawasaki FJ180V engine capable of delivering 5.5 horsepower. It uses unleaded gasoline and features a variable speed rear wheel drive system with six forward speeds. The mower has an electric start and recoil start, a 21-inch cutting width, and a cutting height that can be adjusted between 1 to 3.5 inches. The mower also has a grass bag with a 2.4 bushels capacity, and it weighs 75 pounds. The machine has a steel deck and comes with 9-inch front swivel wheels and 9-inch rear wheels. The mower is designed for ease of use and can be cleaned using an easy access wash port.
Technical Specifications
- Model Number: 247.889210
- Product Type: Walk Behind Mower
- Engine: Kawasaki FJ180V 4-stroke overhead valve single cylinder
- Displacement: 179cc
- Power: 5.5 hp
- Fuel Type: Unleaded gasoline, minimum 87 octane
- Oil Type: SAE 30 detergent oil
- Oil Capacity: 18 oz
- Cutting Width: 21 in
- Cutting Height: 1-3.5 in (6 adjustable positions)
- Drive Type: Variable speed rear wheel drive
- Speeds: 6 forward
- Start Type: Electric start and recoil start
- Deck Material: Steel
- Wheels: 9 in front swivel wheels, 9 in rear wheels
- Weight: 75 lb
- Grass Bag Capacity: 2.4 bushels
- Assembled Weight: 75 lb
- Assembled Dimensions: 60 in x 23 in x 41 in
Warranty
The Craftsman Walk Behind Mower 247.889210 comes with a 2 year limited warranty, which covers defects in materials and workmanship for non-commercial use. This warranty includes the cost of repair or replacement of defective parts. However, it does not cover wear items like belts, blades, and filters beyond initial use, nor does it cover damage caused by improper maintenance, misuse, or accidents. If the mower is used commercially, the engine warranty is limited to 1 year. To claim the warranty, proof of purchase is required, and the mower deck and engine serial numbers must be provided. The mower can be taken to any Craftsman service center or repair can be scheduled by contacting Craftsman customer service. It's important to note that the warranty is limited to defect repair and replacement of parts only, and does not cover incidental or consequential damages. This warranty only applies to units purchased and operated in the United States.
