1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
328.3752
Background
The Craftsman Walk Behind Mower 328.375200 is a lawn mower designed for non-commercial use. It is manufactured by Yasui for Sears under the Craftsman brand. The mower is gas powered and features a Briggs & Stratton 675 Series engine. This mower is equipped with a 21-inch cutting width and can adjust the cutting height from 1 to 4 inches, offering six different height positions. It uses a self-propulsion system, powered by rear-wheel drive, to ease the task of mowing.
The mower comes with a steel deck that is resistant to rust. Two features of the mower are the easy starting mechanism and the side discharge function. Its front and rear wheels measure 7 and 8 inches, respectively. The mower uses SAE 30 oil and weighs about 70 lbs. Regular maintenance, as per the manufacturer's recommendations, is required to keep the mower in optimal condition.
Technical Specifications
- Model Number: 328.375200
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 675 Series
- Displacement: 163 cc
- Power: 6.75 ft-lbs gross torque
- Fuel Type: Gasoline
- Oil Type: SAE 30
- Cutting Width: 21 inches
- Cutting Height: 1" to 4" (6 positions)
- Front Wheels: 7 inches
- Rear Wheels: 8 inches
- Deck Material: Steel
- Weight: 70 lbs
Warranty
The Craftsman Walk Behind Mower 328.375200 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship for a duration of two years from the date of purchase. However, the warranty is only valid for non-commercial use by the original purchaser. It's important to note that the warranty excludes issues stemming from normal wear and tear, improper maintenance, and any form of abuse. To claim the warranty, proof of purchase is required. It's also worth noting that the warranty for the engine is covered separately by the engine manufacturer. Proper maintenance, as per the manufacturer's recommendations, is required to uphold the warranty.
