6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.3704
Background
The Craftsman Walk Behind Mower 917.370400, manufactured by Roper Corp for Sears, is a rotary lawn mower designed for home use. The mower is equipped with a 22-inch rear discharge and powered by a Briggs & Stratton 550 Series engine. The mower is notable for its variable speed control and power propulsion, which provide the user with flexibility and ease in cutting various lengths of grass. It includes a mulching feature which allows grass clippings to be returned to the lawn as a natural fertilizer.
This mower runs on unleaded gasoline and has a fuel capacity of one quart. It uses different types of oil depending on the temperature, SAE 30 above 32°F and SAE 5W-30 below 32°F. The oil capacity is 16 ounces. The cutting width is 22 inches and the cutting height ranges from 1-3/4 to 4 inches, with 9 adjustable positions. Other specifications include 7-inch front wheels, 8-inch rear wheels, a steel deck material, and a recoil start. The mower operates at a blade speed of 3000 RPM.
Technical Specifications
- Model Number: 917.370400
- Engine Type: Briggs & Stratton 550 Series 9P702-0009-F1
- Displacement: 163 cc
- Power: 5.5 ft-lbs gross torque
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 1 quart
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 16 ounces
- Cutting Width: 22 inches
- Cutting Height: 1-3/4 to 4 inches (9 positions)
- Discharge Method: Rear discharge
- Mulching Plug: Included
- Grass Catcher: Optional accessory
- Wheel Size: 7-inch front, 8-inch rear
- Deck Material: Steel
- Blade Length: 22 inches
- Blade Speed: 3000 RPM
- Starting Method: Recoil
- Drive Type: Variable speed front wheel drive
- Safety Features: Operator presence control bar
Warranty
The Craftsman Walk Behind Mower 917.370400 comes with a 2-year full warranty. This warranty covers the entirety of the product, ensuring that the mower operates as it should. In order to claim this warranty, you should refer to the owner's manual or contact the manufacturer directly. It's essential to keep a record of your purchase, as proof of purchase may be required to validate your warranty claim. Regular maintenance as specified in the owner's manual is recommended to prolong the life of the mower and prevent issues from occurring, which might not be covered by the warranty.
