6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.370583
Background
The Craftsman Walk Behind Mower 917.370583 is a lawn mower designed for residential use. Manufactured by Roper Corp for Sears under the Craftsman Brand, the mower is powered by a Briggs & Stratton 124T05-0904-B1 4-cycle engine with a displacement of 190cc and a power rating of 6.75 ft-lbs Gross Torque. The mower uses unleaded regular gasoline and has a fuel capacity of 1.6 quarts. It uses SAE 30 oil above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 oz. The mower has a 21" steel blade and a cutting width of 21", with a cutting height adjustable between 1-3/4" to 4". The front wheels are 7" in size, while the rear wheels are 8". The mower weighs 92 lbs.
The Craftsman Walk Behind Mower 917.370583 is equipped with several features that enhance its functionality. It has a power-propelled rear-wheel drive and can start electrically, with a recoil backup. The height can be adjusted in 7 positions. Additionally, the mower has the ability to mulch, rear bag, or side discharge, and uses a metal mulching blade. The wheels have a dust blocking feature and are equipped with ball bearings. A folding T-handle allows for convenient storage. To maintain the mower, the engine oil should be checked before each use and replaced after the first 5-8 hours of operation. After that, it should be replaced every 25 hours or at least once a year. The air filter should be checked and cleaned regularly or replaced once a year. The spark plug should be replaced and the blade sharpened at the start of each mowing season.
Technical Specifications
- Engine: Briggs & Stratton 124T05-0904-B1 4-cycle engine
- Displacement: 190cc
- Power rating: 6.75 ft-lbs Gross Torque
- Fuel capacity: 1.6 quarts unleaded regular gasoline
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 oz
- Blade: 21" steel blade
- Cutting width: 21"
- Cutting height: 1-3/4" to 4" (7 positions)
- Wheel size: 7" front, 8" rear
- Weight: 92 lbs
- Drive: Power propelled rear-wheel drive
- Starting system: Electric start with recoil backup
- Height adjustment: 7-position
- Mowing capabilities: Mulching, rear bagging or side discharge
- Blade type: Metal mulching blade
- Wheel type: Dust blocking ball bearing wheels
- Handle: Folding T-handle for storage
Warranty
The Craftsman Walk Behind Mower 917.370583 comes with a 2-year full warranty from the date of purchase. This warranty covers any manufacturer defects in material or workmanship, ensuring the mower meets the quality and functionality standards set by the company. However, please note that the warranty period is reduced to 90 days if the mower is used commercially. The warranty does not extend to parts subject to normal wear and tear, those damaged due to improper maintenance, or issues arising from improper use of the product. To claim the warranty, you should retain your proof of purchase and reach out to the manufacturer or your retailer.
