5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37076
Background
The Craftsman Walk Behind Mower 917.370760 is a gas-powered rotary lawn mower manufactured by Roper Corp for Sears. It is equipped with a Briggs & Stratton 126T02-1024-B1 4-cycle engine with automatic choke and a displacement of 123 cc. The mower features a cutting width of 21 inches and an adjustable cutting height, ranging from 1 to 3 inches, facilitated by 9-position height adjusters. The machine uses a variable speed front wheel drive and is started via a recoil method.
This mower also features a steel 21 inch blade and provides rear bag and side discharge options for grass collection. Among its unique features is a "washout" fitting on the deck that allows for quick cleaning with a garden hose. For maintenance, it is advised to check or change the engine oil every 25 hours of operation, clean the underside of the mower deck, inspect or replace blades, and clean the air filter annually. The engine uses SAE 30 standard detergent motor oil and the spark plug type is Champion RJ19HX, with a gap of 0.030 inches.
Technical Specifications
- Model Number: 917.370760
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 126T02-1024-B1 4-cycle engine with automatic choke, 123 cc displacement
- Cutting Width: 21 inches
- Cutting Height: Adjustable between 1-3 inches via 9-position height adjusters
- Drive: Variable speed front wheel drive
- Start: Recoil start
- Blade: Steel 21 inch blade
- Grass Collection: Rear bag and side discharge options
Warranty
The Craftsman Walk Behind Mower model 917.370760 comes with a warranty that spans 2 years for both the mower and its engine. This comprehensive warranty covers any defects in material and craftsmanship that may arise within this period. However, it's worth noting that the warranty period is shortened to 90 days if the mower is used for commercial or rental purposes. In order to claim the warranty, it is generally necessary to contact the manufacturer or the retailer from whom the mower was purchased. It might be required to provide proof of purchase and a detailed description of the issue.
