2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37088
Background
The Craftsman 917.370881 is a walk behind lawn mower manufactured by Roper Corp. for Sears. This model is equipped with a Briggs & Stratton 625 Series engine. It has a displacement of 163 cc and generates a power of 5.5 ft-lbs torque. The fuel type needed is unleaded gasoline with a fuel capacity of 0.8 quarts. The type of oil required changes depending on the temperature; SAE 30 is used above 32°F, and SAE 5W-30 is used below 32°F. The mower has an oil capacity of 15.5 oz.
The Craftsman 917.370881 has a cutting width of 22 inches. The cutting height is adjustable and ranges from 1-4 inches. The mower utilizes a 22 inch steel blade. The mower operates with all wheel drive and has variable speed control. It is started with a recoil start and weighs approximately 60 lbs. Some additional features include a 6 position height adjustment lever, an all wheel drive for improved traction, a removable rear discharge chute for mulching, bagging or side discharge capabilities, an easy start recoil starter, dual point height adjusters, and an operator presence control bar. Regular maintenance is necessary for optimal operation.
Technical Specifications
- Model Number: 917.370881
- Engine: Briggs & Stratton 625 Series 93J02-0010-F1
- Displacement: 163 cc
- Power: 5.5 ft-lbs torque
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 0.8 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 15.5 oz
- Cutting Width: 22 inches
- Cutting Height: 1-4 inches (adjustable)
- Blade: 22 inch steel blade
- Drive: All wheel drive
- Speeds: Variable speed control
- Start: Recoil start
- Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower model 917.370881 comes with a two-year full warranty. This warranty covers any defects in materials or workmanship. Specific parts covered under the warranty include the engine, mower deck, and other parts, provided they are operated and maintained in accordance with the instructions provided in the owner's manual. However, the warranty does not cover normal wear and tear, improper use or abuse of the equipment, and maintenance or replacement of normal wear items such as blades, belts, air filters, or spark plugs. Furthermore, use of gasoline containing more than 10% ethanol could void the warranty. To claim the warranty, refer to the owner's manual for instructions on how to contact Sears or an authorized dealer.
