6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.370931
Background
The Craftsman Walk Behind Mower 917.370931 is a self-propelled, gas-powered lawn mower. It is equipped with a Briggs & Stratton 128M05-5468-F1 163cc engine and is able to hold 1.6 quarts of unleaded gasoline. The oil capacity is 18 oz, with the type of oil used depending on the temperature. The cutting deck measures 22 inches in width and can be adjusted to heights ranging from 1-3/4 to 4 inches. The mower offers mulching, rear bagging, and side discharge options.
Additional features include a dual lever, variable speed self-propulsion drive and electric start button. The mower has 8-inch front wheels and 11-inch rear wheels for easy maneuverability. It comes with a 40V 2Ah battery and charger. The operator presence control bar and a folding T-shaped handle are also included. The mower measures 43 x 21 x 40 inches and weighs 94 lbs. The deck is made of stamped steel and the handle height can be adjusted.
Technical Specifications
- Model Number: 917.370931
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 128M05-5468-F1 163cc
- Engine Power Rating: 5.50 ft-lbs torque
- Fuel Capacity: 1.6 quarts of unleaded gasoline (87 octane minimum)
- Oil Capacity: 18 oz SAE 30 oil (above 32°F), SAE 5W-30 (below 32°F)
- Cutting Deck Width: 22 inches
- Height Adjustment: Single point, from 1-3/4 to 4 inches
- Cutting Options: Mulching, rear bagging, and side discharge
- Drive: Dual lever, variable speed self-propulsion
- Wheel Size: 8 inch front wheels, 11 inch rear wheels
- Starting Method: Electric start button
- Battery: 40V 2Ah battery and charger included
- Operator Control: Operator presence control bar
- Handle: Folding T-shaped handle, with adjustable height
- Dimensions: 43 x 21 x 40 inches (L x W x H)
- Weight: 94 lbs
Warranty
The Craftsman Walk Behind Mower 917.370931 comes with a 2-year full warranty. This warranty covers any defects in material or workmanship for the given period. However, it does not cover expendable parts, attempted repairs or modifications, normal wear and tear, improper maintenance, or accidental damage. To claim the warranty, it will likely require contacting Sears Brands or visiting one of their parts centers. However, the actual process can depend on the terms and conditions of the warranty provided by the manufacturer at the time of purchase. Always refer to your warranty documentation for specific instructions.
