3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.371813
Background
The Craftsman Walk Behind Mower 917.371813 is a lawn mower produced by Sears. This 21-inch push lawn mower is equipped with a 160cc Honda GCV160 engine. The mower is versatile and can be utilized for several tasks, including mulching, bagging, and side discharging grass clippings.
The mower comes with specifications such as a Honda GCV160 engine, a single-cylinder overhead valve that has a power of 5.5 hp. It uses unleaded gasoline and has a fuel capacity of 1.0 quarts. The oil capacity of the mower is 18.5 oz, and the type of oil used varies depending on the temperature. The mower has a cutting width of 21 inches and a cutting height that can be adjusted between 1 and 3.75 inches across seven positions. This mower is capable of mulching, rear bagging, and side discharging. The weight of the mower is 60 lbs.
In terms of features, the Craftsman Walk Behind Mower 917.371813 has dual ball bearing wheels, an operator presence control bar, three convertible cutting options, a single point height adjustment with seven positions, and a rust-resistant aluminum alloy deck.
Technical Specifications
- Model Number: 917.371813
- Product Type: Walk Behind Mower
- Engine: 160cc overhead valve single cylinder, Honda GCV160
- Power: 5.5 hp
- Fuel: Unleaded gasoline
- Fuel Capacity: 1.0 quarts
- Oil Capacity: 18.5 oz
- Oil Type: SAE 30 above 32°F, SAE 10W-30 below 32°F
- Cutting Width: 21 inches
- Cutting Height: Adjustable 1-3.75 inches (7 positions)
- Cutting Options: Mulching, rear bagging, and side discharge capability
- Weight: 60 lbs
- Wheel Type: Dual ball bearing wheels
- Additional Feature: Operator presence control bar
- Height Adjustment: 7 position single point
- Deck Material: Rust resistant aluminum alloy
Warranty
The Craftsman Walk Behind Mower 917.371813 comes with a 2-year limited warranty. This warranty typically covers defects in materials or workmanship. To claim the warranty, you are usually required to provide proof of purchase, such as a receipt or invoice, and contact the manufacturer or retailer. The specific processes may vary, so it is important to check the user manual or warranty card for detailed instructions.
