4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
917.372881
Background
The Craftsman Walk Behind Mower 917.372881 is a gas-powered lawn mower manufactured by Roper Corp for Sears under the Craftsman Brand. This mower is designed with a self-propelling feature, allowing it to move without being pushed. It is powered by a 163cc Briggs & Stratton engine and has a steel cutting deck that is 21 inches wide.
In terms of specifications, the mower has a cutting height that can be adjusted from 1-3/4" to 3-3/4" with seven different height settings available. The front wheel drive system is variable and engaged by a single lever. The mower's fuel tank can hold up to 0.9 gallons of gas and the entire unit weighs 92 lbs. The mower starts with a recoil pull start method. It is designed to handle both mulching and side discharge with a dual port clipping deflector. The front wheels are 7 inches while the rear wheels are 10 inches.
Technical Specifications
- Model Number: 917.372881
- Product Type: Walk Behind Mower
- Engine: 163cc Briggs & Stratton auto-choke engine
- Cutting Width: 21 inches
- Cutting Height: Adjustable from 1-3/4 inches to 3-3/4 inches in 7 positions
- Drive System: Variable front wheel drive, engaged with single lever
- Deck: 21 inches steel cutting deck
- Start Method: Recoil pull start
- Fuel Tank Capacity: 0.9 gallons
- Weight: 92 lbs
Warranty
The Craftsman Walk Behind Mower 917.372881 comes with a 2-year limited warranty that covers any defects in materials or workmanship. This warranty is specifically for non-commercial use and is only valid for the original purchaser of the product. It is important to note that the engine warranty is separately covered by Briggs & Stratton. To claim the warranty, in case of any covered defects, one should contact the Sears or Craftsman customer service, providing proof of purchase and details about the defect.
