2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.374351
Background
The Craftsman Walk Behind Mower 917.374351 is a gas-powered lawn mower produced by the Roper Corporation for Sears. This mower is equipped with a Briggs & Stratton 128T02 1270cc engine, providing a power output of 3.5 horsepower. The mower has a cutting width of 22 inches, and the cutting height can be adjusted between 1 and 3.5 inches. It uses unleaded gasoline and has a fuel capacity of 1.6 quarts. The oil type used varies based on temperature, with SAE 30 being used above 32°F and SAE 5W-30 below 32°F. The mower weighs around 100 pounds and features 8 inch rear wheels and 7 inch front wheels.
The Craftsman 917.374351 is a self-propelled rotary lawn mower that offers variable forward speeds up to 3.5 mph, allowing the user to control the pace. It is designed with a single lever for each wheel to adjust the 6 different height positions. The mower operates using a recoil start and an automatic choke, eliminating the requirement of priming or choking the engine beforehand. The engine drives the 22 inch steel mower blade, facilitating multiple options for handling grass clippings, including mulching, rear bagging, or side discharging.
Technical Specifications
- Model Number: 917.374351
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 128T02 1270cc engine
- Power: 3.5 hp
- Cutting Width: 22 inches
- Cutting Height: 1-3.5 inches (adjustable)
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 1.6 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 ounces
- Wheel Size: 8 inch rear wheels, 7 inch front wheels
- Weight: 100 pounds
Warranty
The Craftsman Walk Behind Mower 917.374351 comes with a comprehensive 2-year full warranty. This warranty covers any defects in materials or workmanship for non-commercial use. It takes care of the repair or replacement of defective parts. However, it's important to note that the warranty does not cover normal wear items such as blades, belts, and air filters. It also excludes any damages caused by improper maintenance or misuse of the product. To claim this warranty, it is necessary to register the product with the original proof of purchase.
