1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.374352
Background
The Craftsman Walk Behind Mower 917.374352 is a gas-powered lawn mower produced by Roper Corp for Sears. It is characterized by a 22-inch cutting width and is powered by a Briggs & Stratton 128T02-1270-B1 engine. This lawn mower has a displacement of 126 cc with a power output of 3.5 hp. It utilizes unleaded regular gasoline with a fuel capacity of 1.6 qt. The oil type for this mower is SAE 30 above 32°F, SAE 5W-30 below 32°F, with an oil capacity of 20 oz.
The mower is designed for residential use, featuring a self-propelled front wheel drive system with variable speed control. It has a cutting height that can be adjusted between 1-3/4 and 3-3/4 inches allowing for 7 different settings. The 22" steel blade is designed to cut efficiently and the side discharge muffler ensures smooth operation. The mower can function as a mulcher with the installation of a mulching plug or can be altered to a side discharger or rear bagger with appropriate attachments. The housing of the mower is steel and the blade can be replaced using a removable blade adapter.
Technical Specifications
- Model Number: 917.374352
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 128T02-1270-B1 4-cycle engine
- Displacement: 126 cc
- Power: 3.5 hp
- Fuel Type: Unleaded regular gasoline, 1.6 qt capacity
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F, 20 oz capacity
- Cutting Width: 22 inches
- Cutting Height: 1-3/4" to 3-3/4" in 7 adjustable positions
- Starter: Recoil pull start
- Drive: Front wheel self-propelled variable speed with rear wheel traction assist
- Blade: 22" steel blade
- Blade Torque: 35-40 ft-lbs
- Muffler: Side discharge
- Safety Features: Operator presence control, engine zone control
Warranty
The Craftsman Walk Behind Mower 917.374352 comes with a full warranty valid for 2 years from the date of purchase. This warranty covers any defects in both materials and workmanship for non-commercial use of the product. It includes parts and labor on covered repairs, but it's important to note that it does not apply to normal wear items, or damage resulting from improper use or neglect. To claim the warranty, users should maintain a record of the purchase date and follow the manufacturer's guidelines for proper use and maintenance.
