6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.374362
Background
The Craftsman walk behind mower 917.374362 is a lawn mower that is both self-propelled and gas-powered. It was manufactured by Roper Corp for Sears under the Craftsman brand. This mower model is equipped with a Briggs & Stratton 128T05-1268-B1 163cc EXi OHV engine which uses electronic fuel injection. It boasts a engine power rating of 5.5 ft-lbs Gross Torque. The cutting width of the mower is 22 inches and it offers a cutting height that is adjustable between 1-3/4" to 4" in 6 positions. The mower operates on a variable speed front wheel drive system and has a blade speed of 3,100 RPM. Starting the mower is facilitated by an electric key start with a recoil backup. The fuel tank capacity is 1.6 quarts of unleaded regular gasoline and the oil capacity ranges between 18-20 oz of SAE 30 oil (above 32°F) or SAE 5W-30 (below 32°F). The weight of the mower is 66 lbs.
The mower has a set of features that include dual ball bearing wheels and a 7 position height adjustment lever. It also offers the flexibility for mulching, side discharge or rear bagging. It comes with a 2-year full warranty.
Technical Specifications
- Model Number: 917.374362
- Product: Craftsman Walk Behind Mower 917.374362
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 128T05-1268-B1 163cc EXi OHV with electronic fuel injection
- Engine Power Rating: 5.5 ft-lbs Gross Torque
- Cutting Width: 22 inches
- Cutting Height: 1-3/4" to 4" adjustable in 6 positions
- Drive System: Variable speed front wheel drive
- Blade Speed: 3,100 RPM
- Starter: Electric key start with recoil backup
- Fuel Tank Capacity: 1.6 quarts unleaded regular gasoline
- Oil Capacity: 18-20 oz SAE 30 oil (above 32°F); SAE 5W-30 (below 32°F)
- Weight: 66 lbs
Warranty
The Craftsman walk behind mower model 917.374362 comes with a full warranty that lasts for 2 years. This warranty covers defects in materials and workmanship for non-commercial use. If the product is used commercially, the warranty coverage shortens to only 90 days. The warranty covers repairs or replacements if a repair is not possible. However, the warranty does not cover normal wear parts such as blades, belts, air filters, and spark plugs. It also does not cover damages caused by improper maintenance or storage, misuse, negligence, or accidents. To claim the warranty, contact the manufacturer with details of the defect or issue.
