5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37443
Background
The Craftsman Walk Behind Mower 917.374430 is a lawn mower that operates on unleaded gasoline. It is a gas-powered, self-propelled machine that enables users to manage their lawns efficiently. The mower is equipped with a Briggs & Stratton 125K02-0370-E1 6.75 HP engine that powers the 22-inch steel blade. The fuel capacity is 1.6 quarts and it uses SAE 30 or SAE 5W-30 oil type, depending on the temperature, with an oil capacity of 20 ounces. The blade bolt torque is 35-40 ft-lbs and it uses a Champion RJ19HX spark plug with a gap of 0.030".
The mower offers a variable speed rear wheel drive and a height-adjustable cutting deck that ranges from 1-3/4" to 4". It provides multiple options for handling grass clippings, including mulching, rear bagging, and side discharge capabilities. Other features include an operator presence control bar and a folding handle for storage. The mower is started by priming the engine three times, holding down the operator presence control bar, and pulling the starter cord. The cutting height is adjustable and the self-propelled rear wheel drive is engaged by holding the operator presence control bar down to the handle and pulling the drive control bar up to the handle.
Technical Specifications
- Model Number: 917.374430
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 125K02-0370-E1 6.75 HP
- Fuel type: Unleaded gasoline, minimum 87 octane
- Fuel capacity: 1.6 quarts
- Oil type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
- Oil capacity: 20 ounces
- Blade: 22" steel blade
- Blade bolt torque: 35-40 ft-lbs
- Spark plug: Champion RJ19HX, gap 0.030"
- Cutting width: 22"
- Drive: Variable speed rear wheel drive
- Cutting deck height adjustment: 1-3/4" to 4"
- Grass handling: Mulching, rear bagging, and side discharge capabilities
- Operator presence control: Control bar
- Storage: Folding handle
Warranty
The Craftsman Walk Behind Mower 917.374430 comes with a 2 year limited warranty. This warranty covers any defects in materials and workmanship under normal, non-commercial use. However, it is important to note that parts subject to normal wear and tear such as belts, blades, and filters are not covered under this warranty. Additionally, any issues that arise due to improper use, lack of maintenance, or abuse of the mower are not included in the warranty. To claim the warranty, it is recommended to contact the manufacturer, Sears, with proof of purchase and details of the defect or issue encountered.
