2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.374545
Background
The Craftsman Walk Behind Mower 917.374545 is a gas-powered lawn mower. This self-propelled mower is designed with a 22-inch steel mowing deck and is powered by a Briggs & Stratton 128T02-1608-B1 163cc engine. This mower is equipped with features such as a single point height adjustment lever, operator presence control bar, and a 3-in-1 convertible deck for mulching, bagging or side discharge. It also includes a variable speed self-propulsion system.
The Briggs & Stratton 128T02 OHV engine is a 163cc engine with a power of 5.5 foot-pounds of torque. It's designed to start easily and does not require priming or choking before starting. The engine also has maintenance features like a spark plug for easy access, a premium foam air filter for improved airflow, and an oil drain for clean oil changes. The mower's 22-inch deep-drawn steel cutting deck offers a 21-inch cutting path and allows for mulching, rear bagging, or side discharge mowing. The cutting height can be adjusted in 7 positions from 1 to 3.75 inches. This mower is capable of handling both flat and uneven terrain.
Technical Specifications
- Model Number: 917.374545
- Product Type: Walk Behind Mower
- Manufacturer: Sears Brands
- Engine: Briggs & Stratton 128T02-1608-B1 163cc OHV
- Displacement: 163cc
- Power: 5.5 ft-lbs torque
- Fuel Tank Capacity: 1.6 quarts (unleaded regular gasoline)
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 ounces
- Deck Size: 22 inches
- Cutting Height: 1-3.75 inches (7 positions)
- Mulching Capable: Yes
- Rear Bagging Capable: Yes
- Side Discharge Capable: Yes
- Wheel Size: 8 inch front, 11 inch rear
- Weight: 66 lbs
- Speed: Up to 3.5 MPH
- Handle Material: Rust-resistant steel with foam comfort grips
- Cutting Deck Material: Deep-drawn steel
- Cutting Swath: 21 inches
- Starting System: Easy pull, no priming or choking required
- Safety System: Automatic choke and zone start
- Maintenance Features: Spark plug for easy access, premium foam air filter for enhanced airflow, oil drain for mess-free oil changes
- Adjustment Lever: Single point height adjustment lever
- Terrain: Handles flat and uneven terrain
- Grass Collection: Rear access door for easy bag change.
Warranty
The Craftsman Walk Behind Mower 917.374545 comes with a 2-year full warranty. This warranty covers any defects in materials and workmanship that may arise within two years from the date of purchase. To claim the warranty, it's likely that you will need to provide proof of purchase, such as the receipt. Specific instructions for claiming the warranty might be found in the product's operator manual or by contacting Craftsman directly. Please note that warranty terms may vary, so it's important to check the exact terms and conditions laid out in your product's warranty information.
