6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37454
Background
The Craftsman Walk Behind Mower 917.374540, manufactured by Roper Corp for Sears, is a gas-powered rotary lawn mower. The machine is equipped with a Briggs & Stratton 4-cycle engine with 127cc displacement providing 3.75 ft-lbs gross torque. It has a cutting width of 22 inches, with an adjustable cutting height between 1 and 3.75 inches. The mower is variable speed rear wheel drive, with speeds ranging from 0 to 3.5 mph forward. It operates on a recoil start system.
The Craftsman Walk Behind Mower 917.374540 is versatile, with the capability to mulch, rear bag, or side discharge grass clippings. It is initially set up as a mulcher but can be modified for rear bagging or side discharging. The mower's deck is made of steel and it rolls on 8 inch front wheels and 11 inch rear wheels. The machine weighs 55 lbs. Maintenance recommendations include regular checks on engine oil, air filter cleaning, blade sharpening or replacement, and cleaning of the mower deck underside.
Technical Specifications
- Model Number: 917.374540
- Product Type: Walk Behind Mower
- Engine: 4-cycle engine with 127cc displacement
- Power: 3.75 ft-lbs gross torque
- Cutting Width: 22 inches
- Cutting Height: 1-3.75 inches adjustable via single point height adjuster
- Drive Type: Variable speed rear wheel drive
- Speeds: 0-3.5 mph forward
- Starter: Recoil start
- Mulching Capable: Yes
- Rear Bagging Capable: Yes
- Side Discharge Capable: Yes
- Deck Material: Steel
- Wheels: 8 inch front wheels, 11 inch rear wheels
- Weight: 55 lbs
Warranty
The Craftsman Walk Behind Mower 917.374540 comes with a 2-year full warranty. This warranty covers any defects in material and workmanship that may arise. However, it is important to note that the warranty becomes void if the mower is used for commercial purposes. To claim the warranty, it would be necessary to retain the original purchase receipt as proof and contact the manufacturer, Sears, directly with details of the defect. It's also essential to ensure that the product is used and maintained according to the instructions provided to avoid inadvertently voiding the warranty.
