6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.374821
Background
The Craftsman Walk Behind Mower 917.374821, a product of Roper Corp for Sears under the Craftsman brand, is a gas-powered lawn mower. This 21-inch mower operates with a 6.75 hp Craftsman engine model 143.046702 and uses regular unleaded gasoline with a minimum of 87 octane. It utilizes a 21" stamped steel blade, has a recoil starter, and a variable speed front wheel drive transmission. The cutting width is 21 inches, and the cutting height can be adjusted from 1 to 3.5 inches, with a total of seven positions.
The mower includes several features, like variable speed front wheel drive, which provides the ability for the operator to self-propel the mower. It can also function as a mulcher when using the rear mulching plug and closed mulcher door. For rear bagging, the mulch plug can be removed and a 2.5 bushel grass catcher can be attached. In the case of side discharge, a discharge chute is attached while the mulch plug is installed. The mower also has a handle that can be folded for storage, and it offers three adjustable handle positions. The wheels measure 8 inches in the front and 9 inches in the rear.
Technical Specifications
- Engine: 6.75 hp
- Fuel Capacity: 1.25 quarts unleaded regular gasoline, minimum 87 octane
- Oil Type: 20 oz SAE 30 above 32°F, SAE 5W-30 below 32°F, API service classification SG-SL
- Blade: 21" stamped steel
- Blade bolt torque: 35-40 ft-lbs
- Starter: Recoil
- Transmission: Variable speed front wheel drive
- Cutting width: 21 inches
- Cutting height: 1-3.5 inches (7 positions)
- Mulching Capability: Yes, with rear plug and closed mulcher door
- Rear Bagging Capability: Yes, with grass catcher
- Side Discharge Capability: Yes, with discharge chute
- Wheels: 8-inch front, 9-inch rear
Warranty
The Craftsman Walk Behind Mower 917.374821 comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship for non-commercial use. However, it is important to note that normal wear parts such as belts, blades, and filters are not included in this warranty coverage. In the case of the engine, its warranty is separately covered by the engine manufacturer. To claim the warranty, the user should follow the guidelines specified in the product's manual or contact the manufacturer's customer service.
