6 Diagrams
No Answers 0 Score |
Engine revs up & down while mowing? |
Documents
Models
917.37545
Background
The Craftsman Walk Behind Mower 917.375450 is a lawn mower produced by Roper Corp for Sears. It is equipped with a Briggs & Stratton 2-cycle Overhead Valve (OHV) engine and features a 22-inch multi-cut deck. The mower utilizes a power-propelled mechanism, which aids in easier navigation around the lawn.
The mower is designed with numerous functions. It has the ability to mulch, rear bag and side discharge grass clippings, providing a range of options to handle grass disposal. It is also equipped with a height adjustment feature that allows the user to set the cutting height from 1 to 3.75 inches, depending on the length and conditions of the grass. Another notable feature is the electric start, which eliminates the need for pull-starting the engine, but it requires a 12V battery for operation. Furthermore, the mower is designed with a Zone Start safety system, ensuring the operator is behind the mower handle to start and operate the blade. The mower deck and underside can be easily cleaned by attaching a garden hose to the provided fitting.
Technical Specifications
- Model Number: 917.375450
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton OHV, 159 cc
- Power: 5.0 HP
- Fuel tank capacity: 1.6 quarts unleaded gasoline
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 18 oz
- Blade: 22" steel
- Blade bolt torque: 35-40 ft-lbs
- Cutting height: 1-3.75" (7 positions)
- Mulching capability: Yes
- Grass catcher: Rear bag
- Discharge type: Side
- Start type: Electric (battery not included)
- Safety feature: Zone start
Warranty
The Craftsman Walk Behind Mower 917.375450 comes with a 2-year full warranty from the date of purchase. This warranty covers any defects in the material or workmanship of the product. However, it's important to note that the warranty is applicable only for individual use and does not extend to commercial use or if the product is rented out to others. Furthermore, the warranty does not cover parts subject to normal wear and tear, or damages resulting from improper maintenance or abuse. To claim the warranty, one would typically need to reach out to Craftsman or Sears Brands Management Corp with proof of purchase and details about the defect or issue.
