2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37552
Background
The Craftsman Walk Behind Mower 917.375520 is a lawn mower produced by Roper Corp for Sears. It is a gas-powered rotary mower designed for maintaining lawns and green spaces.
The mower operates using a 6.5 horsepower Briggs & Stratton 4-cycle engine, model 123K02-0564-E1. It has a fuel capacity of 1.6 quarts of unleaded regular gasoline. The oil used is SAE 30 above 32°F and SAE 5W-30 below 32°F with an oil capacity of 20 ounces. It cuts grass with a 22" steel blade and uses a variable speed front wheel drive. The cutting height is adjustable, ranging from 1-3.5 inches in 6 different heights. Additionally, this mower can be used with an optional rear bag attachment for collecting grass clippings. The mower has an operator presence control bar, which allows the mower to start and operate when it is held down to the handle. The engine speed is set by the factory and is not adjustable by the user. Regular checks for oil and fuel are recommended as the mower is shipped without these.
Technical Specifications
- Model Number: 917.375520
- Product Type: Walk Behind Mower
- Engine: 6.5 horsepower Briggs & Stratton 4-cycle engine, model 123K02-0564-E1
- Fuel capacity: 1.6 quarts unleaded regular gasoline
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 ounces
- Blade: 22" steel blade
- Drive: Variable speed front wheel drive
- Cutting height: 1-3.5 inches in 6 adjustable heights
- Grass catcher: Optional rear bag attachment
- Safety feature: Operator presence control bar
Warranty
The Craftsman Walk Behind Mower 917.375520 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship for non-commercial use, excluding wear items such as belts, blades, air filters, etc., or problems caused by improper use or poor maintenance. The engine warranty is separately covered by Briggs & Stratton. To claim the warranty, refer to the procedures outlined in the product documentation or contact the manufacturer directly. Make sure to keep your purchase receipt and product documentation as proof of purchase date for warranty purposes.
