2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376153
Background
The Craftsman Walk Behind Mower 917.376153 is a gas-powered lawn mower, produced by Roper Corporation for Sears. The primary features of this mower are its 22-inch multi-cut steel deck and a 6.75 horsepower Briggs & Stratton engine.
This walk-behind mower is propelled by a variable speed front wheel drive system, which is engaged by holding down the operator presence control bar and pulling the drive control bar up towards the handle. It provides an option to either mulch or rear bag grass clippings. The cutting height is adjustable, ranging from 1 to 3.5 inches, which can be modified by moving the height adjusters on each wheel. It is important to check the engine oil before each use and change it after the initial 5-8 hours of operation. Regular inspection of the air filter and blade is recommended, with replacement necessary when they become dirty or worn out.
Technical Specifications
- Model Number: 917.376153
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 125K02-0658-E1 4-cycle engine
- Displacement: 163 cc
- Fuel Type: Unleaded regular gasoline
- Fuel Capacity: 1.6 quart
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Cutting Width: 22 inches
- Cutting Height: 1-3.5 inches (9 positions)
- Blade: 22 inch steel blade
- Blade Torque: 35-40 ft-lbs
- Drive: Variable speed front wheel drive
- Deck Material: Steel
- Mulching: 2-in-1 mulching/rear bagging
- Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower 917.376153 offers a 2-year full warranty that covers defects in material or workmanship. However, it should be noted that this warranty does not cover normal wear parts or damage caused by improper use or lack of maintenance. For those using the mower for commercial purposes, the warranty duration is shorter, extending up to 90 days only. If you need to claim the warranty, you will generally need to provide proof of purchase and contact the manufacturer directly. Always consult your warranty documentation for the specifics as procedures may vary.
