5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376164
Background
The Craftsman Walk Behind Mower 917.376164 is a gas-powered lawn mower produced by Sears under the Craftsman brand. The mower is powered by a 6.75 horsepower Briggs & Stratton 4-cycle engine, model 125K02-0658-E1, featuring an overhead valve design and a recoil start system. The engine speed is preset at the factory and cannot be adjusted. The mower’s 22-inch cutting deck is made of steel and has an adjustable cutting height ranging from 1-1/2" to 4" in 9 increments.
The mower operates with a variable speed front wheel drive and a drive control located on the handle. It utilizes a belt-driven transmission system. The mower offers side or rear bagging and mulching capabilities. The handles can be folded for storage. The mower requires SAE 30 detergent oil and the paper cartridge air filter needs to be replaced every 100 hours of use. The blade is to be sharpened or replaced as needed and at least once a year. Regular maintenance as described in the owner's manual is recommended.
Technical Specifications
- Engine Type: 4-cycle, 6.75 horsepower Briggs & Stratton, model 125K02-0658-E1
- Engine Features: Overhead valve design, Recoil start, Maximum engine speed preset at factory (not adjustable)
- Cutting Deck Width: 22 inches
- Cutting Deck Material: Steel
- Cutting Height Adjustment: 1-1/2" to 4" in 9 increments
- Drive System: Variable speed front wheel drive
- Drive Control: Located on handle
- Transmission: Belt-driven
- Safety Feature: Blade brake stops blade within 3 seconds after releasing operator presence control, Operator presence control bar
- Additional Features: Side or rear bagging capability, Mulching capability, Easy fold handles for storage
Warranty
The Craftsman Walk Behind Mower 917.376164 comes with a 2-year full warranty that commences from the date of purchase. This warranty covers any defects that may arise from materials or workmanship. However, it is important to note that this warranty does not cover parts that are subject to normal wear. In order to claim the warranty, you typically have to provide proof of purchase showing the purchase date. Specific instructions for making a warranty claim may vary and should be included in the owner's manual. Following these instructions should ensure that your warranty claim is processed efficiently and correctly.
