2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
917.376231
Background
The Craftsman Walk Behind Mower 917.376231 is a gas-powered lawn mower produced by Roper Corp for Sears. It operates with a Briggs & Stratton 124T02 1225 Series engine that has a power of 6.75 ft-lbs gross torque. It uses unleaded regular gasoline with a fuel tank capacity of 1.6 quarts. It has a 22" steel mower deck and the cutting height can be adjusted to 9 different positions ranging from 1 to 3.75 inches.
The mower offers mulching, rear bagging, and side discharge capabilities. For mulching, a mulching plug is used to recirculate grass clippings. For bagging, there is a 2.5 bushel fabric grass catcher that collects clippings. For side discharge, a chute is attached to the side of the deck to discharge clippings. The mower also features dual lever height adjustment, accessible cutting height positions, operator presence control bar, and variable speed control.
Technical Specifications
- Engine: Briggs & Stratton 124T02 1225 Series with primer, 190cc
- Power: 6.75 ft-lbs gross torque
- Fuel tank capacity: 1.6 quarts unleaded regular gasoline
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 oz
- Mower deck: 22" steel
- Cutting height: 1-3.75 in, 9-position height adjustment
- Blade: 22 in steel
- Blade bolt torque: 35-40 ft-lbs
- Starter: Recoil
- Mulching capable: Yes, with mulching plug
- Rear bag capable: Yes, 2.5 bushel grass catcher
- Side discharge capable: Yes, with discharge chute
- Wheels: 7 in front, 8 in rear
Warranty
The Craftsman Walk Behind Mower 917.376231 comes with a 2-year full warranty that covers any defects in materials or workmanship. This includes the costs of both parts and labor needed to repair any defects that may arise. However, it is important to note that this warranty is reduced to 90 days if the mower is used commercially. The warranty does not cover normal wear parts such as belts, blades, and air filters, and any evidence of abuse or neglect can result in the warranty being voided. To claim the warranty, one would typically need to provide proof of purchase and contact the manufacturer or authorized service center detailing the issues experienced.
