2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376395
Background
The Craftsman Walk Behind Mower 917.376395 is a gas-powered rotary lawn mower. It's notable for its Briggs & Stratton 126T02-1443-B1 engine with a displacement of 159cc and a power output of 5.5 foot-pounds of torque. It utilizes unleaded gasoline and has a 1.6 qt tank capacity. The mower's blade is 22 inches in diameter and has a cutting width of 22 inches. The cutting height can be adjusted from 1 to 3 inches. The mower is equipped with 7-inch front wheels and 8-inch rear wheels. It weighs approximately 75 lbs.
The Craftsman 917.376395 is a self-propelled walk behind mower with a 22-inch steel mowing deck. The mower is designed to mulch, bag or side discharge grass clippings. The cutting height can be adjusted in 6 increments using a single lever for each wheel. The mower features a foldable T-shaped handle with adjustable height.
Technical Specifications
- Model Number: 917.376395
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 126T02-1443-B1 with pull start
- Displacement: 159cc
- Power: 5.5 foot-pounds torque
- Fuel Type: Unleaded gasoline
- Fuel Tank Capacity: 1.6 qt
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Cutting Width: 22 inches
- Cutting Height: 1-3 inches adjustable
- Blade: 22 inch steel
- Torque for Blade Bolt: 35-40 ft-lb
- Front Wheel Size: 7 inches
- Rear Wheel Size: 8 inches
- Weight: 75 lbs
Warranty
The Craftsman Walk Behind Mower 917.376395 comes with a 2-year full warranty. This warranty covers any defects stemming from materials and workmanship, but only applies to non-commercial use of the product. However, it does not extend to normal wear parts like belts, blades, and air filters. In addition, it's important to note that the engine warranty is managed separately by Briggs & Stratton. To claim the warranty, one should likely reach out to the retailer or manufacturer, although the precise process isn't specified in the document.
