6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37646
Background
The Craftsman Walk Behind Mower 917.376460 is a gas-powered rotary lawn mower. Manufactured by the Roper Corporation for Sears, this mower is equipped with a 22-inch cutting deck and relies on a 675 Series Briggs & Stratton engine. The engine, with a displacement of 163 cc, provides a power rating of 5.5 ft-lbs torque. The mower utilizes unleaded regular gasoline, accommodating up to 1.6 quarts in its fuel tank. In terms of oil, it can accommodate 20 oz of SAE 30 above 32°F or SAE 5W-30 below 32°F.
In operation, the mower offers a range of cutting heights from 1-3/4" to 4", adjustable via nine different positions. The mower uses a 22" steel blade and is equipped with 7" front wheels and 11" rear wheels. The mower also includes an operator presence control bar and offers mulching, bagging, and side discharge capabilities. To start the mower, the operator needs to hold down the operator presence control bar to the handle and pull the starter cord quickly. The cutting height can be adjusted by moving the wheel height adjusters. The mower can be switched between mulching, bagging, or side discharge functions by installing the appropriate attachments. The mower's speed is controlled by the operator presence bar and the drive control bar.
Technical Specifications
- Engine: Briggs & Stratton 675 Series 126T02-1045-B1
- Displacement: 163 cc
- Power Rating: 5.5 ft-lbs torque
- Fuel Tank Capacity: 1.6 quarts unleaded regular gasoline
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Cutting Width: 22 inches
- Cutting Height: 1-3/4" to 4" (9 position adjustment)
- Blade Type: 22" steel blade
- Wheel Size: 7" front, 11" rear
- Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 917.376460 comes with a 2-year full warranty. This warranty covers any defects in the material or workmanship of the product. However, it's important to note that the warranty becomes void if the product is used commercially. If you need to make a claim on the warranty, refer to the owner's manual for detailed instructions. Usually, this process involves providing proof of purchase and contacting the manufacturer or the retailer. Remember that repair or modification of the mower by anyone other than authorized service providers may void the warranty.
