2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.3764
Background
The Craftsman Walk Behind Mower 917.376400 is a walk-behind rotary lawn mower that was made by Roper Corp for Sears. This lawn mower is equipped with a 126T02 Briggs & Stratton 4-cycle engine and it uses unleaded gasoline. It has a 22-inch cutting width and the cutting height can be adjusted according to the user's preference. The mower offers rear bagging, mulching, and side discharge capabilities. To prevent accidental starting, the mower is furnished with an operator presence control bar. The mower also features a power-propelled drive system with variable speed control.
This model is designed to provide reliable service for residential yard care when properly operated and maintained. Routine maintenance items for the mower include changing the engine oil every 25 hours of operation, cleaning or replacing the air filter annually, replacing the spark plug annually, sharpening or replacing the blade annually, and cleaning the underside of the mower deck periodically.
Technical Specifications
- Model Number: 917.376400
- Product: Craftsman Walk Behind Mower
- Product Type: Walk Behind Mower
- Manufacturer: Sears
- Type: Walk-behind rotary mower
- Engine: 126T02 Briggs & Stratton 4-cycle engine
- Cutting Width: 22 in
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 1.6 quarts
- Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
- Oil Capacity: 20 oz
- Spark Plug: Champion RJ19HX (gap .030 in)
- Blade Bolt Torque: 35-40 ft-lbs
- Capabilities: Rear bagging, mulching or side discharge
- Safety Feature: Operator presence control bar
- Drive System: Power propelled drive system with variable speed control
Warranty
The Craftsman Walk Behind Mower 917.376400 comes with a two-year full warranty, which covers any defects in material or workmanship. However, it's important to note that the warranty does not include parts that are subject to normal wear and tear, parts that have not been properly maintained, or damage caused by operator abuse or negligence. To claim the warranty, customers need to provide valid proof of purchase and contact the Sears customer service. The defective parts or the entire product may be replaced or repaired, depending on the nature of the defect.
