6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376536
Background
The Craftsman Walk Behind Mower 917.376536 is a self-propelled, gas-powered lawn mower designed for residential use. This mower is equipped with a 163cc Briggs & Stratton engine with an automatic choke feature, and an electric starter with a recoil backup option. The mower's power drives a 22-inch steel deck and a variable speed front wheel drive system. The deck includes a mulching capability and a rear bagging option with a 2.4 bushel capacity.
The mower provides a cutting width of 22 inches, and its cutting height can be adjusted between 1-3/4 to 4 inches in six positions. The speed can be modified by the variable speed drive control located on the handlebars. Additional features include a service minder interval monitoring and a zone start safety system, which necessitates the operator to hold down the control bar to start the mower. Regular maintenance, such as oil changes, air filter cleaning, blade sharpening/replacement, and tire pressure checks, is recommended for the optimal performance of the mower.
Technical Specifications
- Model Number: 917.376536
- Product Type: Walk Behind Mower
- Engine: Briggs & Stratton 126T05-1349-B1 163cc with automatic choke
- Cutting Width: 22 inches
- Cutting Height: Adjustable between 1-3/4 to 4 inches in 6 positions
- Drive System: Variable speed front wheel drive
- Starter: Electric start with recoil backup
- Mulching Capability: Deck allows for rear bagging or mulching.
Warranty
The Craftsman Walk Behind Mower 917.376536 comes with a two-year full warranty which covers any defects in materials and workmanship. However, if the mower is used commercially, the warranty period is limited to 90 days. The warranty does not include normal wear parts such as belts, blades, air filters, and it also does not cover issues resulting from improper maintenance or use, as well as any damage from debris pickup. To claim the warranty, the mower should be returned to any Sears store or service center. Please note, this warranty is only valid while the product is used within the United States.
