5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37657
Background
The Craftsman Walk Behind Mower 917.376570 is a lawn mower that uses a gasoline engine for its operation. Manufactured by Roper Corp for Sears, this machine aids in maintaining and trimming grass in residential and commercial lawns. The machine requires gasoline and oil to function, with a gasoline capacity of 1.6 quarts of unleaded regular gasoline and an oil capacity of 20 ounces. Specific oil types are recommended based on temperature conditions. The machine's blade bolt torque is detailed at 35-40 ft-lbs. It uses a Champion RJ19HX spark plug with a .030" gap.
For operating the mower, the oil level needs to be checked before use and filled to the full line on the dipstick. The machine employs a pull starter handle for operation without the need for choking or priming. The cutting height can be adjusted, and refueling is suggested only after the engine has cooled down. The mower can be used in a self-propel mode by employing the control bar and drive control lever. In terms of maintenance, the oil, air filter, and spark plug need to be replaced at regular intervals or seasonally. The blades may need sharpening or replacing to prevent damage to the grass. The mower also needs cleaning regularly to prevent buildup. For storage, it is recommended to empty the fuel system and lubricate the machine.
Technical Specifications
- Model Number: 917.376570
- Product: Craftsman Walk Behind Mower 917.376570
- Product Type: Walk Behind Mower
- Manufacturer: Sears, Roebuck and Co.
- Power Source: Gasoline
- Gasoline Capacity: 1.6 quarts unleaded regular
- Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
- Oil Capacity: 20 ounces
- Blade Bolt Torque: 35-40 ft-lbs
- Spark Plug: Champion RJ19HX, gap .030"
Warranty
The Craftsman Walk Behind Mower 917.376570 comes with a limited two-year warranty that covers any defects in material and workmanship, provided the product is maintained according to the instructions given in the manual. However, for commercial use, the warranty is only valid for 90 days. It's important to note that the warranty does not include expendable parts such as blades, belts, and air filters, and it also doesn't cover damage resulting from operator abuse or negligence, like bent crankshafts from hitting objects. To claim the warranty, refer to the user manual instructions or contact the manufacturer directly.
