1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376581
Background
The Craftsman Walk Behind Mower 917.376581 is a gas-powered lawn mower that was manufactured by the Roper Corp for Sears under the Craftsman brand. It comes equipped with a 6.75 horsepower Briggs & Stratton 4-cycle engine, model 125K02-0500-E1. The mower has a cutting width of 22 inches and an adjustable cutting height of 1-3.75 inches. The mower features a variable speed rear wheel drive and a 22 inch steel blade. It operates via a recoil start and has a fuel capacity of 1.6 quarts of unleaded gasoline.
The Craftsman 917.376581 is designed for residential lawn care. Its variable speed rear wheel drive enables the mower to be self-propelled at a comfortable walking speed. The cutting height can be adjusted to suit the type of grass being mowed. The mower has dual functionality and can be used as a mulcher or with a rear grass collection bag. It can also side discharge with an optional attachment. The Craftsman 917.376581 is a mid-sized walk behind mower suitable for most residential lawn mowing needs.
Technical Specifications
- Model Number: 917.376581
- Product Type: Walk Behind Mower
- Engine: 6.75 horsepower Briggs & Stratton 4-cycle engine, model 125K02-0500-E1
- Engine Displacement: 163 cc
- Starting Method: Recoil
- Fuel Type: Unleaded gasoline
- Cutting Width: 22 inches
- Cutting Height: 1-3.75 inches, adjustable in 6 positions
- Drive: Variable speed rear wheel drive
- Transmission Type: Geared
- Blade: 22 inch steel blade
- Mulching and Rear Bagging Capability: Yes
- Side Discharge Chute: Optional accessory
- Fuel Capacity: 1.6 quarts
- Weight: 95 lbs
Warranty
The Craftsman Walk Behind Mower 917.376581 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship encountered during non-commercial use. However, for commercial or rental use, the coverage period is limited to just 90 days. It's important to note that the warranty doesn't cover normal wear items such as belts, blades, and brake pads. The engine warranty is handled separately by Briggs & Stratton. In order to claim the warranty, refer to the warranty section in the owner's manual or contact Craftsman or Briggs & Stratton directly.
