2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376654
Background
The Craftsman Walk Behind Mower 917.376654 is a lawn mower designed for residential use. It is a rotary mower with a 22-inch cut width, powered by a Briggs & Stratton 625 Series engine. The mower uses gasoline as fuel and features a self-propelling mechanism to assist with movement.
The Craftsman Walk Behind Mower 917.376654 has multiple functional options for dealing with grass clippings. It can mulch the grass, collect it in a rear bag, or discharge it from the side. The cutting height of the mower is adjustable, ranging from 1 inch to 4 inches to accommodate different lawn conditions and preferences. The mower's engine requires regular unleaded gasoline, and its oil capacity is 20 ounces. It utilizes a Champion RJ19LM or J19LM spark plug and requires an oil change after its first 5 hours of use, then every 25 hours or season thereafter.
Technical Specifications
- Model Number: 917.376654
- Product Type: Walk Behind Mower
- Engine Type: Briggs & Stratton 625 Series
- Cutting Width: 22 inches
- Gasoline Capacity: 1.6 Quarts Unleaded Regular
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Spark Plug: Champion RJ19LM or J19LM, gap .030"
- Blade Bolt Torque: 35-40 ft-lbs
- Cutting Height: Adjustable from 1" to 4"
- Functionality: Can mulch, rear bag or side discharge grass clippings
- Assembly Location: USA
Warranty
The Craftsman Walk Behind Mower 917.376654 comes with a 2-year full warranty, which covers any manufacturer defects in material or workmanship. However, if used commercially, the warranty is valid for 90 days from the purchase date. The warranty does not extend to expendable parts such as blades, belts, air filters, and spark plugs. Additionally, it does not cover damages resulting from operator abuse, negligence, or failure to maintain the mower properly. The warranty is also not applicable for use outside of the United States. To claim the warranty, refer to the instructions provided in the operator's manual or contact the manufacturer directly.
