2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.376781
Background
The Craftsman Walk Behind Mower 917.376781 is manufactured by Roper Corp for Sears under the Craftsman brand. It is a self-propelled, gas-powered rotary lawn mower. The mower utilizes a 160cc Honda GCV160 4-stroke overhead cam engine with an auto choke and auto-throttle system. It has a fuel capacity of 1.0 quart of unleaded regular gasoline and an oil capacity of 18.5 oz, with a recommendation to use SAE 30 oil above 32°F or SAE 10W-30.
The central component of this machine is its 21" multi-cut steel deck, offering mulching, rear bagging, and side discharge capabilities. The height of the deck can be adjusted to 9 positions ranging from 1-3/4" to 4". The Craftsman Walk Behind Mower 917.376781 is designed with a variable speed front wheel drive and an automatic self-propelled system that engages when the operator presence control bar is held down. It measures 63.5" L x 23" W x 40.5" H and weighs 94 lbs.
Technical Specifications
- Model Number: 917.376781
- Product Type: Walk Behind Mower
- Engine: 160cc Honda GCV160 4-stroke overhead cam engine
- Fuel Capacity: 1.0 quarts unleaded regular gasoline
- Oil Capacity: 18.5 oz, uses SAE 30 oil above 32°F or SAE 10W-30
- Cutting Deck: 21" multi-cut steel deck
- Cutting Heights: 9 position height adjustment from 1-3/4" to 4"
- Drive System: Variable speed front wheel drive, Automatic self-propelled system
- Dimensions: 63.5" L x 23" W x 40.5" H
- Weight: 94 lbs
- Handle: Adjustable height
- Wheels: 8" front wheels and 12" rear wheels
- Suitable for: Yard sizes up to 1/2 acre
Warranty
The Craftsman Walk Behind Mower 917.376781 comes with a 2-year full warranty. This warranty covers any defects that may occur due to materials or workmanship within this time period. However, it's important to note that expendable parts such as blades, belts, and air filters are not covered under this warranty. To claim the warranty, you'll need to provide proof of purchase and contact the manufacturer or the retailer where you bought the mower. They'll guide you through the process of addressing the defect and, if necessary, repairing or replacing the mower.
