2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37707
Background
The Craftsman Walk Behind Mower 917.377070 is a lawn mower that was produced by the Roper Corporation for Sears under the Craftsman brand. It is a gas-powered, self-propelled mower with specifications that include a 21-inch cutting width and a Briggs & Stratton 6.5 HP 4-cycle engine. The mower's cutting height can be adjusted to nine different positions, ranging from 1 to 3 inches. Additional features include an electric key start and manual recoil start, a variable speed front wheel drive, and a 21" steel mulching/bagging blade. Grass discharge can be managed through side discharge, rear bagging, or mulching options.
The mower includes a 2.5 bushel rear grass bag and has 8" wheels both in the front and the back. It has a fuel tank capacity of 1.6 quarts for unleaded gasoline and an oil capacity of 20 ounces of SAE 30 oil. The overall weight of the mower is 61 lbs. Regular maintenance of the mower should include checking the engine oil level before each use, replacing the oil after the first 5 hours of use and then every 25 hours of use thereafter. The air filter should be checked regularly and replaced annually, and the spark plug should also be replaced annually. The blade should be checked for sharpness and signs of wear and replaced as needed. The underside of the mower should be cleaned regularly to prevent the buildup of grass clippings.
Technical Specifications
- Model Number: 917.377070
- Product Type: Walk Behind Mower
- Engine: 6.5 HP 4-cycle
- Cutting Width: 21 inches
- Cutting Height: 1-3 inches (9 position adjusters)
- Drive: Variable speed front wheel drive
- Start: Electric key start and manual recoil start
- Blade: 21" steel mulching/bagging blade
- Grass Discharge: Side discharge, rear bagging or mulching
- Grass Catcher: 2.5 bushel rear grass bag included
- Wheels: 8" front wheels, 8" x 1-3/4" rear wheels
- Fuel Tank Capacity: 1.6 quarts unleaded gasoline
- Oil Capacity: 20 ounces SAE 30 oil
- Weight: 61 lbs
Warranty
The Craftsman Walk Behind Mower 917.377070 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship when the product is used for non-commercial purposes. However, the warranty does not extend to normal wear parts like belts, blades, and filters which require regular replacement. The engine warranty is separately covered by Briggs & Stratton. To claim the warranty, it is typically required to provide proof of purchase and to report the issue within the warranty period. The specific process may vary, so it is recommended to contact the manufacturer or authorized service provider for exact details.
