3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37712
Background
The Craftsman Walk Behind Mower 917.377120 is a gas-powered lawn mower, known for its 21-inch cutting width. It is equipped with a 125cc Briggs & Stratton engine and can be started electrically. The cutting height can be adjusted from 1 to 3.75 inches, with seven different positions available. The mower features rear bag, mulch, and side discharge options, providing flexibility based on the user's needs. It is designed with 8 inch rear wheels and 7 inch front wheels, and weighs around 60lbs.
This walk behind mower also comes with dual point height adjusters to facilitate the adjustment of cutting height. For operation, it uses both ignition key and pull cord mechanisms. The machine can switch between mulching, rear bagging or side discharge modes without the need for tools. To operate the mower, there is an operator presence control bar that needs to be held down. The mower requires regular maintenance, including changing the engine oil after the first 5 hours of use and then every 25 hours, inspecting and cleaning or replacing the air filter as needed, and inspecting, sharpening, or replacing the blade as necessary.
Technical Specifications
- Model Number: 917.377120
- Product Type: Walk Behind Mower
- Engine: 125cc Briggs & Stratton with electric start
- Cutting Width: 21 inches
- Cutting Height: 1-3.75 inches (7 positions)
- Grass Management: Rear bag, mulch or side discharge capabilities
- Wheel Size: 8 inch rear wheels, 7 inch front wheels
- Weight: 60 lbs
- Height Adjustment: Dual point height adjusters
- Start Method: Electric start via ignition key or pull cord
- Safety Feature: Operator presence control bar
- Mode Conversion: Tool-free conversion between mulching, bagging, and side discharge modes
Warranty
The Craftsman Walk Behind Mower 917.377120 comes with a 2-year full warranty. This warranty covers defects in materials and workmanship for 2 years from the date of purchase. The warranty is applicable solely for personal household use and does not cover the mower if used for commercial purposes. Under the warranty, the main components such as the engine, deck, and main frame are covered for the entire 2-year period. However, other parts like batteries, belts, and blades are not covered beyond 90 days from the purchase date if used commercially. To claim the warranty, you may need to provide proof of purchase and likely will need to contact the manufacturer or authorized service center.
