3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.37715
Background
The Craftsman Walk Behind Mower Model 917.377151 is a gas-powered rotary lawn mower. This model is manufactured by Roper Corp for Sears under the Craftsman brand. The engine is a 6.0 HP Briggs & Stratton 4-cycle engine, Model 12H802, Type 2640-B1. The fuel type used is unleaded regular gasoline, with a capacity of 1.6 quarts. The oil used is SAE 30 above 32°F and SAE 5W-30 below 32°F with a 20 oz capacity. The mower has a steel blade that cuts with a width of 22 inches and the cutting height can be adjusted in 7 increments between 1-3.5 inches. The drive is a variable speed front wheel drive and the mower uses a recoil start mechanism.
The Craftsman Model 917.377151 is a self-propelled rotary lawn mower. It has a front wheel drive system with variable speed control. The cutting height can be adjusted in 7 positions from 1-3.5 inches, providing flexibility for optimal grass cutting. The mower can perform multiple functions such as mulching, bagging, or discharging grass clippings through the side. The mower has a folding handle for compact storage when not in use.
Technical Specifications
- Engine: 6.0 HP Briggs & Stratton 4-cycle engine, Model 12H802, Type 2640-B1
- Fuel Type: Unleaded regular gasoline
- Fuel Capacity: 1.6 quarts
- Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil Capacity: 20 oz
- Blade: 22" steel blade
- Cutting Width: 22"
- Cutting Height: Adjustable, 1-3.5" in 7 adjustments
- Drive: Variable speed front wheel drive
- Start Method: Recoil start
Warranty
The Craftsman Walk Behind Mower Model 917.377151 comes with a warranty cover from Sears. Specifically, this warranty is a 2-year limited warranty if the product is used for residential purposes. However, the warranty period is reduced to 90 days if the mower is used commercially. The warranty is designed to cover any defects in materials or workmanship of the product. It's important to note that the warranty does not cover damage due to normal wear and tear, misuse of the product, improper maintenance or any form of abuse. To claim the warranty, you would need to contact Sears and provide them with information about the defect. Make sure to keep your purchase receipt or any other proof of purchase as it may be required during the claim process.
