7 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.377532
Background
The Craftsman Walk Behind Mower Model 917.377532 is a lawn care equipment that operates on a Briggs & Stratton 6.0 horsepower engine. It has a displacement of 11.5 cu. in. (190 cc) and runs on unleaded gasoline with an octane rating of at least 87. The fuel capacity is 1.6 quarts (1.5 liters), and it uses either SAE 30 or SAE 5W-30 oil depending on the temperature. The oil capacity is 20 oz (0.6 liters). The mower has a cutting width of 22 inches, and the cutting height can be adjusted between 1 and 3.5 inches. The total weight of the mower is 66 lbs.
The mower has a 22-inch steel deck and offers seven height adjustment settings ranging from 1-3.5 inches. It has options for both side and rear grass discharge. The 6.0 horsepower Briggs & Stratton engine, which starts with a pull recoil, powers this mower. It is designed with a fuel tank that can hold 1.6 quarts of gasoline, allowing it to run for extended periods before refilling is necessary. The Craftsman 917.377532 mower is suitable for a variety of residential lawn care needs, offering a balance of durability, operation, and maintenance.
Technical Specifications
- Engine: Briggs & Stratton 6.0 horsepower
- Displacement: 11.5 cu. in. (190 cc)
- Fuel type: Unleaded gasoline, 87 octane minimum
- Fuel capacity: 1.6 quarts (1.5 liters)
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 oz (0.6 liters)
- Cutting width: 22 inches
- Cutting height: 1-3.5 inches (adjustable)
- Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower Model 917.377532 comes with a 2-year limited consumer warranty. This warranty covers the engine of the mower, ensuring that the buyer is protected against any manufacturing defects or faults that may arise in this period. To claim the warranty, it is typically required to contact the manufacturer, in this case, Sears, with details of the issue and proof of purchase. Always remember to keep your receipt or a copy of it as this usually serves as your proof of purchase. Check with the manufacturer for any specific requirements or exclusions.
