3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.377593
Background
The Craftsman Walk Behind Mower, model 917.377593, is a lawn maintenance tool. It is a push lawn mower with a 22" deck, designed for cutting grass in residential areas. The mower is equipped with a 6.75 horsepower 4-cycle engine (model 143.996704), which gives it the capacity to handle different grass lengths and densities. It has a fuel capacity of 1.5 quarts of unleaded regular gasoline (87 octane minimum) and an oil capacity of 27 oz with the recommended oil types being API SF, SG, SH. The mower uses a Champion RJ19LM spark plug with a gap of .030".
The mower has a range of features that enhance its functionality. It has the capability for rear bagging, mulching, and side discharge, giving the user options for handling grass clippings. The machine also has an 11 position single lever for height adjustment, ranging from 1-3/4" to 4", which allows the user to select the preferred grass length. The mower is designed with a folding T-shaped handle for compact storage and easy start primer carburetor for quick and smooth start-ups. The mower also requires operator presence control to start, ensuring it does not operate unattended.
Technical Specifications
- Model number: 917.377593
- Product type: Walk Behind Mower
- Engine: 6.75 hp 4-cycle
- Displacement: 12.56 cu. in.
- Fuel capacity: 1.5 quarts unleaded regular gasoline (87 octane minimum)
- Oil capacity: 27 oz SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil type: API SF, SG, SH
- Spark plug: Champion RJ19LM (gap .030")
- Blade bolt torque: 35-40 ft-lbs
- Mower deck size: 22"
- Cutting methods: Mulching, rear bagging, and side discharge
- Height adjustment: 11 position single lever from 1-3/4" to 4"
- Handle: Folding T-shaped
- Carburetor: Easy start primer
- Safety feature: Zone start requiring operator presence control to start
Warranty
The Craftsman Walk Behind Mower model 917.377593 comes with a two-year limited warranty. This warranty covers any defects in materials or workmanship for non-commercial use. It includes the cost of replacement parts and labor. However, it doesn't cover expendable parts such as filters, belts, and blades, which are subject to wear and tear from normal usage. The warranty also covers engine and deck housings against defects, but not damage resulting from improper use or abuse. To claim the warranty, the owner typically needs to contact the manufacturer or authorized service provider, providing proof of purchase and specifics about the defect or issue.
