6 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.377661
Background
The Craftsman Walk Behind Mower 917.377661 is a gas-powered lawn mower manufactured by Roper Corporation for Sears under the Craftsman brand. This model is equipped with a 6.5 horsepower Briggs & Stratton engine, model 123K02-0258-E1, with a recoil start and an overhead valve design. The engine has a displacement of 192cc. The mower features a 21-inch steel cutting deck that is capable of rear discharge and height adjustable from 1-3.75 inches in seven different positions.
The Craftsman 917.377661 operates with a self-propelled rear wheel drive and a variable speed front wheel drive control. To operate, the mower requires a presence control bar to be held down to start the engine and engage the blades. Regular maintenance for this model includes changing the oil, replacing the air filter annually or every 100 hours, and replacing the spark plug annually or every 100 hours of use.
Technical Specifications
- Engine Model: Briggs & Stratton 123K02-0258-E1
- Engine Power: 6.5 horsepower
- Engine Start Method: Recoil start
- Engine Design: Overhead valve
- Engine Displacement: 192cc
- Cutting Deck Size: 21 inches
- Cutting Deck Material: Steel
- Cutting Deck Discharge: Rear discharge
- Cutting Height: Adjustable from 1 to 3.75 inches in 7 positions
- Drive System: Self-propelled rear wheel drive
- Speed Control: Variable speed front wheel drive
- Safety Feature: Operator presence control bar that disengages front wheel drive when released
- Maintenance: Regular oil change (SAE 30, 20oz capacity), annual air filter replacement, and annual or every 100 hours spark plug replacement (Champion RJ19LM, gap .030 inches)
Warranty
The Craftsman Walk Behind Mower 917.377661 comes with a 2-year limited warranty. If the product is being used for commercial or rental purposes, the warranty period is reduced to 90 days. This warranty specifically covers any defects in material or workmanship. However, it does not extend to wear items such as belts, blades, and so on. To claim the warranty, you would typically need to present evidence of the defect, such as photographs or physical examination, although the exact process may vary and could require contacting the manufacturer or the store where the mower was purchased. It is advisable to keep all relevant documentation handy, including purchase receipts and warranty cards.
