5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.377783
Background
The Craftsman Walk Behind Mower 917.377783 is a gas-powered, push lawn mower. The mower is equipped with a 21-inch blade, fuelled by a 6.75 horsepower, 4-cycle engine. It utilizes a recoil start mechanism and requires 1.25 quarts of unleaded regular gasoline (87 octane minimum). The engine's oil capacity is 20 ounces of SAE 30 oil (above 32°F) or SAE 5W-30 (below 32°F), with a recommended oil type of API SF-SJ. The spark plug specifications are Champion RJ19LM or J19LM, with a gap of 0.030".
The mower operates with a 21-inch cutting width and variable speed rear-wheel drive. The height is adjustable in 3 positions, ranging from 1-1/4" to 3-3/4", allowing for different grass lengths. The machine affords multiple handling options for grass clippings, including mulching, rear bagging, and side discharge. The mower weighs 135 lbs and has rear wheel dimensions of 9 x 2 inches and front wheel dimensions of 8 x 2 inches. It also features a single-point height adjuster, an adjustable handle with 3 positions, and includes a grass catcher.
Technical Specifications
- Model Number: 917.377783
- Product Type: Walk Behind Mower
- Engine: Craftsman 143.046702 4-cycle engine
- Horsepower: 6.75
- Starting Method: Recoil start
- Fuel Tank Capacity: 1.25 quarts unleaded regular gasoline (87 octane minimum)
- Oil Capacity: 20 ounces
- Oil Type: SAE 30 oil (above 32°F); SAE 5W-30 (below 32°F)
- Spark Plug: Champion RJ19LM or J19LM (gap: 0.030")
- Cutting Width: 21"
- Drive Type: Variable speed rear-wheel drive
- Height Adjustment: 3-position, from 1-1/4" to 3-3/4"
- Operation Options: Mulching, rear bagging, and side discharge
- Blade Bolt Torque: 35-40 ft-lbs
- Weight: 135 lbs
- Rear Wheel Size: 9 x 2 inches
- Front Wheel Size: 8 x 2 inches
- Handle: Adjustable with 3 positions
- Additional Feature: Grass catcher included
Warranty
The Craftsman Walk Behind Mower 917.377783 comes with a 2-year limited warranty. However, the specifics regarding what is covered by the warranty were not detailed in the provided document. To claim the warranty, it is usually required to contact the manufacturer's customer service directly or the retailer where the product was purchased. It is advisable to keep a copy of the receipt or any other proof of purchase as it might be required during the claim process.
